41 - 60 of 72 Posts
· 1689 Federalist
· New to OCN?
Rumored to be $37ish usd
this cant be true, it is too good, but if it's then it is the best thing since the Fanless Raijintek TISIS and the Scythe Fuma
Has to be(If true), no way a dual tower cooler with 1x 140mm & 1x 120mm aRGB fans would be priced under $50.
59
https://www.newegg.com/p/13C-001T-0...ijintek_cpu_cooler-_-9SIA66Z28E4068-_-Product
47
https://www.newegg.com/p/13C-001T-0...ijintek_cpu_cooler-_-9SIA66Z4086023-_-Product
· Just another nerd
Wow 5ghz huh. What are your load temps like?
It depends on ambient temp obviously, plus I have a pretty good chip that doesn't need a lot of vcore for 5 GHz. BFV gaming temps are typically low 70's. It uses all 8 cores.
· PC Enthusiast
· Banned
You seem to have a great 9900k, my 9700k needs 1.35V to get to 5.1/4.8 (core/uncore). I'm surprised you haven't tried for a higher overclock than 5 Ghz. Why not try for 5.2 Ghz.?
· 1689 Federalist
That's pretty nice for 5ghz. Congrats.
· curmudgeon
Must be many years ago then, as they've been selling there since at least 2014...
Amazon price history of 2 of their most popular coolers:
https://keepa.com/#!product/1-B00IYEEOMO
https://keepa.com/#!product/1-B00PKJ21L
Seems to me like you walked past the coffee shop quite a few times :p
Yes I walk past amazon every time.
I am aware of Nan's Gaming Gear but must be a lousy searcher because I could never actually find them before now. This is the one to get. Silver Arrow SB-E Extreme
It can handle 1.55v 24/7/365 with temps rarely touching 70C.
· Just another nerd
My chip is decent but I would not say it's golden. I run a fixed voltage with High LLC and load vcore is typically just 1.248v, 100% stable. I don't bench at all anymore, this rig is only for gaming and there is no reason to push the chip any harder for that purpose.
· Just another nerd
Actually the 8mm x 6 heatpipes on the TS 140 Power are rated higher (360w TDP diffusion) vs the 6mm x 8 heatpipes (320w TPD diffusion) on the SA SB-E.
8mm pipe = ~60w TDP diffused
6mm pipe = ~40w TDP diffused
There are other factors of course. It's too bad they didn't use 8mm pipes with the SA SB-E. :(
· Fix it till its broke
I don’t think TR was using 8mm pipes way back then. But there has to be more to it than just the size of your pipe. TS140P is one of the best coolers I have used, if not the best. And so is LGMRT. Both are very different, and one has 7x 6mm pipes but a crapload of surface area. In my Meshify C I get better results with LGMRT than TS140P because of my airflow configuration. I have two exhaust fans that are basically pulling on the cooler, while four intakes pounding on the face side of the cooler. In conjunction with TY-143 I have 5x 120x38, 1x TY-147A, 1x 90x38 3900 RPM screamer all on a couple of controllers except the TR fans. That all means I can run my cpu right up to one tick before ovp kicks in at 1.525v and my gpu at its limit and not worrry about heat to much. But realistically I can run linpack extreme at 4700mhz1.4v on my 3770K.. I hear that’s water cooling voltage. TS140P can handle 1.6v on a 4800mhz x5690 in my Define R4. No filters or mesh on either case.
That’s a lot of typing on a phone sorry for the novel.
· Banned
Are you using the True Spirit 140 to cool your 9900k?
· Just another nerd
If you are interested in that cooler, be careful with the name because there are three different "true spirit 140" models and the one with the thick heat-pipes is just the "true spirit 140 power".
That's the one I have, it's sold on Amazon and direct though Nan's Gaming Gear in the US.
· Politically incorrect
Thermalright had a two-tower cooler named "IFX-14" over ten years ago, that's older than the NH-D14. That old cooler also had four extra thick 8mm heat-pipes, just like this new one here.
The IFX was an amazing cooler. I loved it and it served me very well. I still have photos of it. Sadly it couldn't keep AMD's Presshot (the BD uArch) cool so I had to replace it with something much better.
· curmudgeon
That is an interesting cooler, but the single weak fan kills its potential. With two TY-143 fans it might be a different story. It's too bad NAN's doesn't seem to have a retail store.
· Facepalm
Wow! They have the Silver Arrow for sale there! It has been unavailable in North America for years. This places the Frost Spirit in perspective. The Silver Arrow is their top of the line model while the Frost Spirit is their mid range model.
Want a 5ghz air cooled FX? The Silver Arrow can do it. I wouldn't even try it with the Frost Spirit. But it should be fine with current CPUs. I just hope that one of those heat pipes is sitting directly over the hot spot on Zen.
Huh ? Which Silver Arrow do you buy? (For Intel, although they seem to include both Intel and AMD mounts). The IVB-E Rev B, or the T8 ?
How does it compare to the Le Grand Macho RT ?
And isn't the True Spirit 140 Power their top of the line cooler now?
· - Insanity Beckons -
Those fatty heatpipes, dang! Looks really nice, have always loved Thermalright products
Nothing better than having some serious John Holmes like tubing running into heatsinks.
Onya Thermalright, this would be the one cooler to own for any CPU board. It'll certainly fracture any setup with it's enormous attributes :thumb: .
· curmudgeon
Did I buy. I have not bought a cooler in years. It is the IVB-E. They sent me the AM4 mount. Cost $5-6 bucks shipped from Germany.
The Macho has lots of fin surface to pull heat out of the pipes but no way to get rid of said heat. I'm a big fan of wind chill and if my puter was set up on wheels it would roll around. The fans are more important than the cooler itself. My proof? I have the only air cooled FX in the 5ghz 24/7 club.
The 8mm pipes on the 140P are interesting in that they have more flow and can react more quickly to sudden temperature changes, but the future is with vapor chambers. Unfortunately the only outfit making those is Coolermaster.
41 - 60 of 72 Posts
