1 - 6 of 6 Posts
I'm running at 2700Mhz, and I've been having some stability probs. I was wondering if chipset voltage might have anything to do with this. I have it 1.62v. Whats my max safe voltage on NF4 SLi?
isnt stock like 1.5 on those guys, im pretty sure that i usually bumbed it up like .1 when on air and when i am using water i usually just max it out since temp is no concern<br />
<br />
with that board doing 300x9 i assume shouldnt have a problem at all
SNERP!!!
I bumped mine up one step from stock.
Retired
If you dont feel comftorable raising your voltage you can always just lower your HTT multiplier, which will put less strain on the NB, thus hopefully taking care of your problem. As for max voltage, I used to run my evga NB at 1.7 24/7.
Discussion Starter #5
<tr>
<div>
Originally Posted by <strong>tubnotub1</strong>
</div>
<div style="font-style:italic">If you dont feel comftorable raising your voltage you can always just lower your HTT multiplier, which will put less strain on the NB, thus hopefully taking care of your problem. As for max voltage, I used to run my evga NB at 1.7 24/7.</div>
</td>
</tr>
</table>
</div>Hmm, well I'm running at 270x10. And my HT multi is already pretty low, not even close to 1000Mhz. Looks like this isn't the source of my instability...<br />
<br />
*sighs*
Retired
<tr>
<div>
Originally Posted by <strong>FlaKing</strong>
</div>
<div style="font-style:italic">Hmm, well I'm running at 270x10. And my HT multi is already pretty low, not even close to 1000Mhz. Looks like this isn't the source of my instability...<br />
<br />
*sighs*</div>
</td>
</tr>
</table>
</div>Try bumping your multiplier down to 2, then run some tests and see if it helps the stability at all. It might work, as it worked for me on my evga board.
1 - 6 of 6 Posts
