1 - 11 of 11 Posts
Hi,<br>
would this will help to bring down temp for P5W DH chipset? compare to the aircooling now on those chipset..which one are better? How many? If you need more detail please let me know. Thank you .<br><a href="http://assets.overclock.net.s3.amazonaws.com/5/55/55cffa24_vbattach34531.jpeg"><img alt="LL" src="http://cdn.overclock.net/5/55/525x525px-LL-55cffa24_vbattach34531.jpeg" style="width:500px;height:375px;"></a>
It looks beautifully engineered- What other blocks would you be running in the loop?
I give you the Link sorry about that <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"><br><a href="http://www.mips-computer.de/index.htm" target="_blank">http://www.mips-computer.de/index.htm</a><br><br>
I asked to myself too? Don't know where I am to use for other block for?
I might add in that often, chipset blocks adds a bit flow restriction and simply isn't worth it.<br>
Swiftech makes a nice HSF for the chipset, which I forgot the name of apart from that it has high pins and a 40mm fan on it.
Discussion Starter #5
<tr>
Swiftech MCX159-CU Chipset Cooler
</td>
</tr>
</table>
</div> is it the one?
<tr>
<div>
Originally Posted by <strong>ntvh</strong>
<a href="showthread.php?s=92c472ab6416178eb1b53b0d775857c3&p=1402377#post1402377" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">is it the one?</div>
</td>
</tr>
</table>
</div> Thats the one...It should cool your NB fine.. Adding a lot of blocks in your loop will kill your flow...Those are some pretty WB's, I'd almost put them in just to look at them..<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />.......<a href="http://www.svc.com/mcx159-cu.html" target="_blank">Swiftech MCX159-CU Extreme Duty All-Copper Heatsink w/ 40mm Fan</a>
<tr>
<div>
<a href="showthread.php?s=92c472ab6416178eb1b53b0d775857c3&p=1402802#post1402802" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">How about for my MOFEST loop? Do you have any suggestion? Thanks</div>
</td>
</tr>
</table>
</div> A fan on your voltage regulater should be plenty...When you WC the temp's on the V-reg. can go up because you have removed the HSF..Put a little 40mm on it or near it should be plenty...
Discussion Starter #9
Thank you for save me more$$$$. Will do that.<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
<div>Originally Posted by <strong>ira-k</strong> <a href="showthread.php?s=92c472ab6416178eb1b53b0d775857c3&p=1402817#post1402817"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">A fan on your voltage regulater should be plenty...When you WC the temp's on the V-reg. can go up because you have removed the HSF..Put a little 40mm on it or near it should be plenty...</div>
</td>
</tr></table></div>
I've found those stick-on heatsinks for video card RAM work great on the mosfet's. Easy, cheap. I did have to hacksaw a few to get them to fit properly....eh...so what.
<div>Originally Posted by <strong>FrankenPC</strong> <a href="showthread.php?s=92c472ab6416178eb1b53b0d775857c3&p=1403279#post1403279"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">I've found those stick-on heatsinks for video card RAM work great on the mosfet's. Easy, cheap. I did have to hacksaw a few to get them to fit properly....eh...so what.</div>
</td>
</tr></table></div>
<br>
Beleive it or not I was just looking at some of those yesterday...Think I will buy a hand full of those micro one's and stick them all over...They got to help some...<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
1 - 11 of 11 Posts
