Table of Contents:
0: The Plan
1: Cable Management Part 1
2: Cable Management Part 2
3: Color Test
4: Sleeve is Here!
5: Prep for Painting and Sneak Peak at Sleeveing
6: Sanded, Primed, and First Coat
7: Changed Plug On Fan Controller and more Sleeving
8: Final Coat of Red and Tape Removed
9: Beginning to Re-Assemble
10: Sleeveing Done and Some Painting Updates
11: Completely Reassembled After Painting and Sleeving
12: Pci Slot Covers
13: Replaced Stock TIM on Video Cards
14: Stealth One of the DVD Drives
15: Water Blocks Are Here!
16: New RAM!
17: Stealthing the DVD Drives, Take 2
18: Internal pics of CPU and Mobo waterblocks
19: Rest of CPU loop unpacked
20: Installed the Top Radiator and Fill Port
21: Under Water At Long Last
22: Re-assembled w/ First Loop
22: Tri-SLI done quick and dirty
23: Two of the Three GPU Waterblocks are Here!
24: Third GPU Block Is Here and A Bit Of Side Project
25: Wall Project Gets Test Fitted
26: Wall Side Project Complete
27: Back in business for real - Last big box of parts unboxed
28: some explanation and thought
29: Disassembly for the final stretch of modding! (07-10-10)
30: Cleaning, Swapping, and Test Fitting (08-10-10)
31: GPU Blocks Installed w/ Backplates
32: Drive Bay Radiator Cover
33: lower section radiator mount
34: Improving the false floor
35: making the false floor sexy
36: painting random stuff that is left to paint
37: GPUs with waterblocks and backplates installed
38: DVD Drive, Fixing Issues, Electrical, and Reservoir Pictures
39: Mounting the Pump
40: Reservoir Mount
41: Issues, Filling the Loop, and More Issues
42: Fixing Problems and Getting the Loop Filled and Leak-Free <almost>
43: Fixing the Res, GPU Block, and Dusting
44: loop back together, final two cables sleeved, and final cable management done
current state of the project (updated with every project update):
0: The Plan
3: Color Test
4: Sleeve is Here!
12: Pci Slot Covers
16: New RAM!
40: Reservoir Mount
