1 - 5 of 5 Posts
i mean if you have the budget go ahead and buy a new mobo but the best solution if you are tight on the $$ just get and extion card plety out there here are some seggestions:
USb 3.0
Sata 6gps
Originally Posted by i7Stealth1366;12036131
Problem with the Asus stuff is that it is does not support my classy
Says who? Asus only lists the stuff compatible with their boards. It will work on yours.
1 - 5 of 5 Posts
