I have a couple of EK radiators made of brass. I had been using a dark red EK premix coolant for a few months and when I took the whole system apart, the coolant had badly stained everything it touched. I was able to clean copper, nickel, and acrylic parts, but I cannot get the brass inside my radiators clean. The surface of the inside is still stained red.
I've let them soak overnight filled with 75% white vinegar / 25% distilled water. I've even let them soak for an hour with 100% vinegar. And I've connected them to a makeshift loop with a pump to run a 50/50 vinegar + distilled water mix through them and let it run for long periods of time, several times. The first time I tried flushing them with vinegar, it pulled up a lot of red that pure distilled water could not get. After flushing and re-filling a couple times, it stopped pulling up red stain and the mixture remained clear, but the inside of the radiator STILL has red coating the inside.
I really wanna get these things sparkly clean with not even a hint of dye stain. Any suggestions? Does Brasso come in liquid (not cream/paste) form? If so, would it be safe to fill up my radiator with it?
