1 - 6 of 6 Posts
I'm trying to find a clear case right now with at least one 120mm fan if not two on the back side of the case. also I would want hopefully at least 5 5 1/2 inch drive's.<br />
<br />
all I've seen are those that have 80mm fans and 4 drive bays so are they not there or am I not looking?
you mean acrylic or just metal ?
acrylic. Not too fond of a lot of the new cases so figured I would just keep it simple and go see through case
you can just mod an acrylic case... then you can have as much 120mm fans as you like (that depends on how much the case can take <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick Out Tongue">)<br><br>
anyway i don't know the shops with acrylic cases, maybe some other guys here on the forums knows <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
Discussion Starter #5
if need be I can dril more fans in there but I would easily like more expansion bays then just 4 if I can
Kind of expensive, but I bet they will have what you want <a href="http://www.clearpc.ca/catalog/index.php?cPath=21&osCsid=f4a419dca0a8eeaa3d1072df32f..." target="_blank">here.</a>
1 - 6 of 6 Posts
