i im new at the forum but i wonder is you guys could help me out .
i got a striker 2 extreme mobo and a q9650 cpu running stable on 4 ghz.
my idle temp is about 45 degr and stress at 55/ 60 .
now i want to take it to 4.5. ghz or higher just to see how far i can go .
the nb and cpu are both watercooled .
cpu volt is 1.40
al the other things stil auto
so any sugestoins would be nice
Check and make sure that you have the RAM voltage set correctly. I dont know if that board lets you unlink the RAM from the FSB or not. But the BSoD most likely points to the RAM because I really wouldn't think it was the board not liking the FSB that high.
You need to focus on voltages. Set the clock speed up to 4000 MHz and make it stable by adjusting the voltages manually. Start from low voltages and increase them a bit in time until your system is stable.
Maybe its the board, but the pll, vvt, nb, and sb voltage seem high. With my ud3p pll 1.5, vvt 1.22, nb 1.22, and sb 1.5. I would tickle those gtl's a little
Why is your SB at 1.5? You only need to bump it depending on your hard drive setup, and you only have one so 1.1 should be fine for you.
Overclock.net
