Hi,
To be added to the boards on Post #2 just post info like below Otherwise you'll be rejected Single Core is optional Multi Core Score is mandatory Screen Shot does have to be easily readable no wasted blank space and Images must be Uploaded to OCN not a image hosting website and linked here !!!!!
Frequencies just round up or down a hair they don't have to be exact
Only one sub per user name highest multi score will erase prior runs.
Show CPU-z with cpu and memory tabs open board section optional
User Name----CPU & Frequency----Memory & Frequency----Single Core Score----Multi Core Score
R20
www.guru3d.com
ThrashZone----9940x @4.9----3600c16 @4000----510----9022
R23 settings need to be this way to do one run so go to File and check Advanced benchmark
Then Switch Minimum test duration to Off.
Sub entries the same way as R20 I have not run it yet
R23
www.guru3d.com
ThrashZone----9940x @4.9----3600c16 @4000----1313----23567
R20
Download MAXON Cinebench R20
Download the all newCinebench. Cinebench is a real-world cross-platform test suite that evaluates your computer's hardware capabilities. Improvements to Cinebench Release 20 reflect the overall adv...
R23
Download MAXON Cinebench R23
Download the all-new Cinebench Release 23. Cinebench is now based on the latest Release 23 code using updated compilers, and has a minimum runtime activated by default (previously hidden in preferenc...
