Have been using Cosmos 1000 for 4 years, I don't OC and do not have tons of HDDs, so case and hd temp are good. I love everything about this case except one thing, cabling.
Hiding cables is an exceptionally challenging task with this case, today when I looked at the cable clutter, I feel that I have to do something......
After an afternoon of hard work......
More holes for cables to go behind mobo, with original holes, cables can't pass through the vertical steel beam, otherwise the side panel won't close......
One hole on top right for 8 pin CPU power cable, also cover all edges with rubber trip to hide ugliness and imperfection
A big hole for installing CPU heat sink is a must
Cut bottom intake fan grill for better airflow, cover the zigzag edge with rubber trim, excuse the yellow duck in the background, it's my dog's toy......
Tools used:
Tools used:
- 1 inch hole saw
- Dremel cutting disc for metal (pack of 5)
- Masking tape
- Rubber trip from MNPCTech
