1 - 13 of 13 Posts
Absolutely awesome.
I have been running stock cooling for a while on this system, which made me feel like less of an enthusiast then the rest of you who have awesome CPU cooling solutions.
Finally, I have joined you all with a push pull configuration of my own!
On the front (Push) I have the stock Hyper 212 plus fan. On the back however, I have a 120mm fan that was taken out of a gateway computer, AVC brand. It has a 4-pin motherboard connector, but I currently have it plugged into a 3-pin slot so it's running full blast at around 80CFM. Yeah it's pretty loud and sounds like a vacuum but it keeps things cool
temps
Current Ambient temperature: 71F / 21.7C
Idle: 73F / 23C (rounded)
Under prime95 load: 42C / 106F (rounded)
Not bad considering I have ambient temps higher than normal. Now for some in action pics
I would have mounted it horizontally so more air was moving around the Mosfets but the bracket only allowed for vertical...
So anyway, I'll be doing a 3.4GHz (yeah yeah it's not 4.0 but I'm on 65nm Here!) overclock tomorrow or whenever I feel like trying to fiddle with it to be stable.
Also, If you are looking for an inexpensive cooler, go for this one - It already came with plastic fan mounts for a second fan, and even 4 sticky anti-vibration pads for it!
Originally Posted by awaizy View Post
I'm like 99% sure the CM 212+ can be oriented horizontally. Are you sure it can't?
The holes on my motherboard were spaced like
I think it's because it's an AMD setup, on an Intel it would mount the other way.
Update:
So I've done some overclocking, reached 3.4GHz (3395MHz) with 1.47 Vcore, I'm about 9 minutes into prime95 without hickups. I tried the two lower notches of voltages before this and had problems each time but none yet.
Originally Posted by newpc
im wondering why is ur gfx card running on the bottom slot? isnt that x8?
It's a silly board, the bottom is x16, and the top is x8.
Discussion Starter · #11 ·
Originally Posted by BlackHoleSon
Update:
Update to update: Upping the vcore one more notch, last night prime95 gave an error on one of the two threads (and the other was fine) and my temps still look okay.
Im running at 3.8 with stock voltage with hyper 212. Same mobo as you too. Did you oc using the multiplier? I was running at 3.9 with 1.425V but it was getting to hot for my likings. I was hitting around 57 Prime 95. Now at 3.8 I hit 46.
Discussion Starter · #13 ·
I have the multiplier left at X 15.5, seeing as how my multiplier doesn't go up.
1 - 13 of 13 Posts
