CM Stacker 830 modding
421 1
Just got the NVIDIA edition one and was thinking of modding it:
Shud i go with all green LED fans or just use Scythe Ultra Kaze and mod with Green Cold Cathode tubes?Which wud look better?
1 - 2 of 2 Posts
Depending which ultra kaze you are going for I don't think it is worth it. Those suckers are loud! You could go with some yate loons or tricools to cut down on noise, the static pressure gain with the ultra kaze wouldnt be worth it imo
and I prefer cathodes over the led fans but thats just my opinion.
1 - 2 of 2 Posts
