1 - 5 of 5 Posts
I just bought the CM Storm Trooper, love the case but not the red led's on the front panel. I am going with a black/yellow color scheme with a few white led's to kind of show off the motherboard I bought alitte better. Anyway back to the subject. The question is how hard would this be to change the red leds to a yellow or white led? Or is this even possible? Any suggestion would be great! I even though about a clear paint to possibly change the red to yellow but not sure. Any suggestions would be great. Thx much...
Red LEDs emit red light only. Painting over them with yellow will merely block a lot of the red light. You won't get yellow. Red, white and yellow LEDs are compatible as far as power requirements. Simply swap them out. I don't know what package size they are though as I don't have one of the cases. Should be T 1-3/4 (5mm) or T-1 (3mm), not some little surface mount stuff.
Pop that panel apart and take some close up pictures and I could tell you more about it.
Originally Posted by nascar8rc View Post
After searching in found someone else wanting to do the same on Overclock.net ( The Official Cooler Master Storm Trooper / Storm Stryker Club page 536 ).
I am currently reading to see if he was able to manage to switch out the LED's. Thanks lots TLHarrell for the help on this...
Originally Posted by Ne1ld0 View Post
This previous post of mine should help you out.
http://www.overclock.net/t/1104349/the-official-cooler-master-storm-trooper-storm-stryker-club/10100#post_21835457
And to answer your question, those 3 tiny LEDs are 3.2mm x 1.6mm SMD LEDs
Thanks Lots Ne1Ido !! What I was looking for....thumbsupsmiley.png Your case looks sweet thumb.gif
1 - 5 of 5 Posts
