CM Xtraflo 120mm fan any good?
7964 6
Anyone have any experience with this fan? I can get them for a very good price and am thinking of getting one or probably two for P/P for my Hyper 212.
They are called blademasters and seem to very similar design to the blademaster that comes with the 212 so I'm guessing they are very similar.
http://www.coolermaster.com/product.php?product_id=6684
1 - 7 of 7 Posts
It's more or less the same as a Blade Master but louder and not as good for heatsink applications due ot the lower static pressure.
Should be fine for the application though.
Less static pressure than a traditional blademaster? I don't understand how that is possible, the design is virtually identical is it not?
It's similar, but the blade dimensions are not the same.
XtraFlo's use a blade of a higher pitch and slimmer width to achieve more airflow at the same RPM but sacrificing static pressure.
I see.. Thanks, learnt something new.
i got them on my Hyper 212+ in push pull and they do the job fine
they perform about the same as 2 blademasters... if not better... if i remember my temperatures correctly.... but yes they do push a hella alot of air!! theres a youtube video somewhere showing it blowing itself around the table :L
p.s. Xtraflo's cable is really really short... but comes with a nice long half sleeved 4pin splitter cable =]
I can add to that.
The cables are REALLY short, they are designed for CPU's that's why. They're a slight bit better then the stock cooler on the 212+. Going from one stock fan to two of these i've seen about 2-4c drop, keep in mind they are a bit louder then the stock fan. Shame really as i kinda damaged the cable on the stock one :/
They look pretty too!
1 - 7 of 7 Posts
