1 - 4 of 4 Posts
First I want to say (Holycats) at how this site has grown and I don't know if im in the right place for a thread start? I am still on the same rig I built years back,,, same specs under my usename. But something has happened while back and it wont keep that overclock anymore,,, I am on the same MB (gigabyte P45 chipset) Wondering if anyone has come up with better specs for what im or was using?
Most likely you will need to replace the CMOS battery (This is a CR2032 battery if I can remember what type it is) it is a circular battery that is on the battery that has most likely gone flat over the years of using the motherboard.
Yeah, if your battery is flat it will reset. But it should not affect your oc results though
1 - 4 of 4 Posts
