1 - 11 of 11 Posts
ok when i start up the game its all fine and dandy while in multiplayer and in single player.... while im looking for a server i find one like everyone else but then i try to join the server u know the screen were it shows a picture of the map and the load bar well the bar goes a quarter way. then it freezes and makes a dun noise. so i minimized the game and it says directx error direct x has encountered an unrecoverable error. Then a ie website pops up about errors for direct x do dx diag etc and none of it works. so then i reinstall direct x the first like 3-5 maps are fine then when the server changes maps it start all over again with the dang error. this concept happens when i install a new driver it all works fine until the 3-5 map into the game then kaput the error pops up again . I would really appreciate someone responding to this because its really bugging me
thx for responding if you know what to do
Originally Posted by Nova_BP View Post
I have the same problem man.. i dunno what to do either :S
i had this issue not so long ago.
uninstall CoD2, uninstall your display drivers, install display drivers, install CoD2.
this worked for me.
nvidia forceware manager and firewall drivers cause conflicts with COD2 (found out the hard way!) Uninstall if you have it loaded.
1 - 11 of 11 Posts
