1 - 4 of 4 Posts
I'm having issues with my 780 Ti DirectCU II OC with code 43 error.
Came home from work, looking at the screen driver isn't working and now having a code 43 error. Tried different drivers from 340 - 347, still doesn't work with the aid of DDU. Haven't tried on the 2nd PCIe 3.0 though. Windows 8.1 Pro x64 is always up to date.
What could be the problem?
PS: I don't have a backup GPU, power supply, or another system to test on.
What should be here ?
Did you try to manually update the driver through the device manager by pointing it to the driver location ?? Also, did you update your bios to the latest one ??
Originally Posted by kifinas View Post
Have you fixed the card?
Yes, fixed it through RMA.
Before sending it though, I tried the card on my friend's PC. Did all troubleshooting measures and still reproduced the same code 43 error. So the card was the culprit.
1 - 4 of 4 Posts
