That's quite something.
yeah on a low power i3, good luck trying to run an 8700K on it. Intel doesn't sell motherboards what difference does it make to them?We all knew it was compatible, just Intel locking it out on purpose to sell new stuff. Good job to these folks for showing it can be done.
They sell the chipsets, which go on the motherboard.yeah on a low power i3, good luck trying to run an 8700K on it. Intel doesn't sell motherboards what difference does it make to them?
Even if it's on a low power processor, why is it so out of the question that this might be capable of getting an 8700 working? I mean, the TDP differences between the 8700 and 8700k are different by about 50%. One is a 95W chip, the other is 65W.yeah on a low power i3, good luck trying to run an 8700K on it. Intel doesn't sell motherboards what difference does it make to them?
power pin allocation, its not that the motherboard can't support higher power usage, but the power pin on the CPU-side is shifted to unused pins on the socket-side.Even if it's on a low power processor, why is it so out of the question that this might be capable of getting an 8700 working? I mean, the TDP differences between the 8700 and 8700k are different by about 50%. One is a 95W chip, the other is 65W.
In any case, this just shows that Intel outright lied about the compatibility issues here. Same socket, new chipset to unlock the new processors, but lock the old ones too. Excessively dumb. Just one more reason to stick to AMD.
You mean to tell me that Intel HAD TO do it that way????power pin allocation, its not that the motherboard can't support higher power usage, but the power pin on the CPU-side is shifted to unused pins on the socket-side.
meaning, theres a risk of burning the CPU itself, the motherboard will survive the load.
it might've been necessary to spread load due to more cores.You mean to tell me that Intel HAD TO do it that way????
I absolutely believe that Intel did this purposely to drive sales.
Don't get me wrong; they have every right to do it. But I'll tell you this: AMD is guaranteed to be in my next build when I move beyond my 5820k.
They have a hard limit of two series per socket, sometimes 1.You mean to tell me that Intel HAD TO do it that way????
they didn't really need to switch sockets though?They have a hard limit of two series per socket, sometimes 1.
Of course this was to drive sales. They didn't even have the z390 ready so z370 isn't even a refresh. How much do you want to bet z390 is going to be a single series socket![]()
they could refresh the chipsets instead, with more interesting features, imagine if they were like this:
100series = 1x M.2, 20 PCIe lanes.
200series = 2x M.2, 30 PCIe lanes, native 2.5gbps Intel NIC.
300series = 3x M.2, 40 PCIe lanes, native 5gbps Intel NIC.
all these wouldn't require a socket swap, however DMI 3.0 would ultimately become the bottleneck.
Actually the i3-8100 pretty much wipes the floor with the similarly priced Ryzen 3 1300x.I still don't see any results of 8600K/8700K at 5GHz+ pulling 200W+ from all this hacking. That's the real deal with Z370. Is 4 real cores for an i3 really the main attraction of Z370? If so, you might as well look toward AMD for equivalent or better performance.
What? The Ryzen 1300x is $115 on newegg right now, but the i3 8350k is $180! At least compare it to the Ryzen 1400 ($160) or the Ryzen 1600 ($190).
