1 - 5 of 5 Posts
Retired
Ok, so for some reason my windows RC 1 has problems sending in results to the [email protected] server. I managed to find away around this and it worked... for a while. Basically what I would do is open up Windows XP (dual boot) and open up the RC1 folder of [email protected] and it would transfer. However, now im getting this when I try to transfer. *sigh* Any ideas would be greatly appreciated! Dont mind the odd colors, changed it to 16bit to lessen the size.<br><br>
EDIT: I would like to clear this up ASAP, as I have joined a team and this is my main rig, and thus, counts toward the team.<br><a href="http://assets.overclock.net.s3.amazonaws.com/b/b4/b417acfd_vbattach33728.bmp"><img alt="LL" src="http://cdn.overclock.net/b/b4/525x525px-LL-b417acfd_vbattach33728.jpeg" style="width:518px;height:525px;"></a>
Retired
Discussion Starter #2
Bumpage...<img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
Humm, I don't know... are Windows Firewalls' Ports open? I'm running [email protected] on both cores with RC2 and haven't had any problems.<br />
<br />
You could also try reinstalling the clients, making sure to use diffrent directories etc... but frankly I'm not sure what's up. <br />
<br />
Any more details?<br />
<br />
<font size="4">EDIT:<br />
<br />
<a href="http://fah-web.stanford.edu/serverstat.html" target="_blank">http://fah-web.stanford.edu/serverstat.html</a><br />
<br />
that paticular server (171.64.122.130) is down... you can wait for it to go back up or close [email protected], delete the work folders, and reboot [email protected] it should query for new servers and new assignements... but the points are lost.<br />
<br />
I shouldn't be helping the competiton <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /></font>
There's no need to delete the work folders. The completed work will transmit once the servers are back up. Meanwhile, new work can be completed. There is plenty of room in the queue for unsent WUs.
Dont worry just yet tubby, your points will start counting for the team in 7 days.
1 - 5 of 5 Posts
