I have found the relic of fans, I wont be using them for my rig as my cooling solutions are good enough already, but to replace my air accelerator for my ducts that has a motor balance issue.
You can see my cable clamps to keep pressure on the motor, and to avoid vibration.
These are the Comair Rotrons, they are ~150mm in blade diameter, have a peak load of 15amps and use 230v. Estimated to be a airflow noise of 36dB, my uncle got these from working in buds cooling section for their beer chillers
They use a 2 pin crimp connection(other one just has contacts on it) and a ground.
Opinions/ Suggestions?
