1 - 20 of 22 Posts
have you overclocked it? it may just be unstable form overclocking it to far... aslo what are your temps if u did OC?
can u look on the side of the PSU and see how many amps is on the +12v rail... im asuming this is a cheapy psu that came with the case u have...
hmmm that sounds a little low for you computer and videocard... i hate to just jump to the conclusion, but i think it could be you PSU, u want something with a little more power than that... something around 24amps minimum on the 12v rail...
does the amd processor required more power then intel? Cause My old motherboard and cpu was an CPU: p4 2.6 , MB: is7 and I had no problem Until i switch to amd 3700+ asus a8v
yes the amd will use more power and so will the motherboard, did u also have the smae video card or did u update that too? so now it does sound like you PSU for sure...
ya it sounds like the PSU to me... how much u willing to spend i can help u fand a good one that will be last for a long time...
Originally Posted by PROBN4LYFE
What voltage are you running to the AGP slot....seems as if you're running it on auto in the bios (normally 1.5V)....try raising it to 1.6 or 1.7
i thought running more voltage to agp can hurt the videocard.... cant it casue unstablility and hurt the gpu?
Originally Posted by g4xx
I just got a new one, Just need to change it. this time its a 550 watt ! My old one is 420 watt ! Will that fix the problem?
How many amps on the 12 volt rail?
it might... is it a cheap one that came with a computer case? how many amps are on the 12v rail for that one?
lol its no different.... u can try it but i doubt it will be much better,if any.... i think u just need to get a little money together and buy a good psu for 50-90$
I've run 1.6-1.7V on every card I own...even my Mx440...(Quadro FX...excuse me flashing
It only hurts if you leave it clocked waaay too high...but mediocre to med-high...it gives the card that extra juice it needs without fooling with the bios...which is another story
so if i throw an extra .1-.2volts into the card and max out the OC it can hurt it? like will i be able to OC more than what i have now if i put more power to the agp slot?
1 - 20 of 22 Posts
