1 - 20 of 22 Posts
Originally Posted by Juggalo23451
It might.
AFAIK, it won't Since XP 32 bit only recognizes 3.5gb, it won't be able to use something that it doesn't even have the ability to see.
Originally Posted by lsvtec View Post
would more ram help with performance eventhough its reading 3.5 only
That's kind of an interesting question actually... I wonder how windows allocates the 3.5GB of memory among the 4GB that is potentially there.
jones bones
That is a good question. I just ordered a 2x2gb set of 1066 mushkins to get ready for win7 while it's still cheap, and to maybe help with my oc on my rig with winxp 32bit home edition. If it does use the extra 1.5gb's, would it also run the 3.5gb's it does "see" in dual channel?
Cuz I'm also hoping to get a little more headroom to reach 4ghz. I gotta zap the crap out of my chip and loosen the ram timing so much, like as loose as they will go, and i still can't get 4ghz w/o bsod's or crashing or failing stability tests almost instantly. I'm coming from ram in my sig.
Only 64-bit versions of Windows will recognize more than 3.5 GB.
jones bones
I know that, i was wondering more along the lines of what superon was asking.
What does win32bit do with what it DOES see?
It uses it....
Reactions: jaz
jones bones
In dual mode? Thanks for responding.
If your RAM is running Dual Channel, then yes.
Reactions: jaz
jones bones
Awesome! rep for you and duckie!
Awesome!! Glad I could help!!
jones bones
You read my mind...i was wondering about the video ram being used also.
It's not the video RAM... it is the I/O mapping space for the video RAM.
jones bones
I think i understand a little more...thanks again.
1 - 20 of 22 Posts
