1 - 2 of 2 Posts
I'm hoping to buy a smaller computer that can handle a high-end VR experience (an hopefully be a little future proof). Happy to buy something prebuilt or build my own. Performance is more important than size, so I'm thinking a GTX 1080. Which direction should I go in, and if the answer is build my own, where can I find a good configuration for this situation?
Thanks!
Not New to OCN
Find a mini-ITX case you like the looks of and build your own. I recently helped a friend build a compact 8700 + used gtx970 system for about a grand, and you can easy upgrade the GPU. You might want to wait as rumor is the gtx1180 will be launching the end of August.
1 - 2 of 2 Posts
