I have never seen a Penitium 4 so can not speak on that item.
There are many models of Celeron of which the "D" is one but the other "Celerons" contain more than one model so you are asking for a large breakdown.
The Celeron "D" is a faster processor than all the other Celeron models:
- 533MHz Bus
- 90nm Strained Silicon Process - More and faster transistors in less space
- 31 Pipeline Stages - Helps with clock speed ramping
- Improved Branch Predictor - Helps to avoid pipeline stall
- Improved Scheduler - Helps to avoid doing unnecessary work
- Improved Execution Core - An added integer multiply and fast shift to ALU
- SSE3 - 13 new instructions
