1 - 8 of 8 Posts
i havnt used those particular ram modules before , what i would do is do a search for that particular modules and it should give a bunch of places that have ran them through the ocing gamet and the results whcih then you can get a loose idea of how they will do, ive used both gskill and ocz in ddr form but those were tccd chips, im not sure what chips they are putting in there ddr2 stuff hopefully micron d8 or whatever there called
The OCZ SOE is the better ram. Its got the tightest timings at ddr800. I thinks its worth the extra few $$.
Discussion Starter #4
yeah i plan on getting a cheat 7900gto and upgrade the ram to 1gb ddrII ocz
Geil Ultras DDR2 among others that use Micron D9 ICs are screamers.
Originally Posted by MADMAX22
some of the crucial ballistic do to (good stuff)
Crucial is Micron.
Micron makes the IC, Crucial is the division that assembles them for retail sales.
1 - 8 of 8 Posts
