Compatibility Issues Between A Chipset & Windows
377 Views 5 Replies 2 Participants Last post by  Hogo
Hey all
Right so having this since I installed vista on my new build what do you make of it?
Ive updated the drivers from the disc that come with the Motherbored.
And its still here so....
Any ideaS?
Ive installed what windows links me to but its old and out dated the one I have now is newer.
Thanks
Rob
Heres what appears when you click it
1 - 6 of 6 Posts
Care to go into the device manager (right click my computer -> properties -> device manager on the left) to show us what specific item it's missing a driver for?
The issue should easily be solved by going to the Gigabyte site and downloading the latest drivers for your motherboard (make sure you get the 64bit vista version)
Good luck and post back if you need further help
Thanks for the reply
il have to check gigabytes website but couldn't find anything last time.
Rob
Hmm installed the latest Gigabyte update and still no luck, Anyone?
you left "system devices" expanded in your screenshot, so I can't see what's missing a driver
unexpand all the tabs under device manager and take another screenshot
1 - 6 of 6 Posts
