1 - 4 of 4 Posts
A media center remote is a media center remote. They should all be cross compatible. For instance, my 2250 came with an IR receiver, and it works just fine with the remote it came with, the xbox360 media center remote, a third party remote I already had, and my Harmony.
Thanks for the info +rep.
Where could I buy just the receiver without the remote?
They are so cheap, they literally don't sell them without a remote that I could find. If you already have a good remote, just buy the cheapest receiver and remote then trash the cheap remote and keep the receiver.
1 - 4 of 4 Posts
