As I mentioned in my last update, I decided to sand the gold/bronze pieces through the clear so I could add a couple more coats of color, and do heavier coats of clear to try to improve the reflective look of the paint that I was aiming for. I also needed to give the second batch of pieces to be painted a light sand to help the paint stick.
Logo needs to be sanded down to give these piece a smoother look..
Then it was back to work with the paint and most of the pieces and accessories to the case. I tried a slightly different painting with aerosol technique this time around and I have to say it turned out much better than before. Instead of putting the pieces an the rack and painting them there, painted each piece individually by holding it in front of me on a wire. It helped me to give better, even coats as well as preventing missed spots.
After painting, sanding and repainting the gold parts..
The second batch of pieces, mostly the exterior case plastic parts, are going to be painted purple. Why purple? That's what was asked for the exterior color. The gold and purple should give the case a unique and interesting look compared to the usual colors that are seen. The gold, despite a lack of shine I had hoped for turned out pretty well. I wanted to copy the similiar color of the gold/bronze/brass dancer poles, with a solid shine. The purple on the other hand needed some extra 'Wow' to set the simplistic colors off. Firstly I needed to use a metallic, high sparkle silver primer coat. I was a bit worried that once I put down the color coat that it would carry the sparkle through..
Then after applying the color coat, I was pleasantly surprised. The color laid down as a very solid, deep purple with some serious shine. Also I noticed along the edges where the paint tended to go on thicker, give a darker highlight, which looks just awesome.
So basically the purple color coat turned out perfect. I doubt a person with a paint gun could have done better, and I just had spray paint. Now to really set off this paint job, I needed to add that extra 'Wow' I mentioned. The second batch of pieces got two coats of the metallic primer, about four or five coats of color, then one coat of clear, one coat of metallic/sparkle clear coat then another two coats of clear to give some depth. The sparkle clear was only added to the purple, where the gold remains solid.
Sadly my camera, or my ability, did not really take quality shots to show the paint as it appears if seen in person, but I'll get some better pictures soon to share. I'm super excited on how this turned out.
And after a little bit of elbow grease with the light hand buff..
The gold, as hoped, gained an improved shine and reflection to it, but still not exactly what I had hoped for, but it will definatly work. All in all I'm pleased with the turn out. I would love to say that I have no more painting to do, but I still have a few miscellanious pieces as well as the side doors and door trim to paint.
Here's a few couple of shots just for comparison to how it looked and how it will look..
Alright, so I guess now it's back to work, still a lot of it to be finished. You'll have to wait and see what comes next. Keep an eye out for the next updates, they will begin to really take shape and give this mod the uniqueness that it's all about.
