Originally Posted by Lunchbox21984
Love it, i dont think i have enough legos to do that mod
. i do have a XBOX system for sale. WINK WINK!!!!!!!!!!!
PMed
Originally Posted by masbuskado
LoL I think this's not a Case Mod this a Custom Built
Look Nice... I should buy bunch of lego block and build a Full ATX Case and even include the Lego People to it...
Nicely Done!!!
Thats a great idea, ill watch out for a project by you!
Originally Posted by Megaman_90
this looks kinda cool. How many Legos did it take you to make it?
Not sure of an exact count, but as a rough estimate, I would say LOTS.
Originally Posted by ZealotKi11er
I am going to mod my Xbox to by changing the back fan and adding 2 USb port. I also reseald the CPU with some OCZ Freeze and it drop the temp from 45C to 40C.
Yeah, I also reseated the cpu block with OCZ Freeze. The heatsink is glued to the MCP with Arctic Silver Ceramique Thermal Adhesive.
There is a fan right in between the hard drive and power supply, although it might be hard to see, there one fan on each the cpu/gpu, and then there is the 80mm led exhaust fan. The slight crack under the case is where the hdd/psu fan takes its fresh air from, and blows it under the board, over and under the psu, and its intake is right beside the motor on the hard drive.
Originally Posted by mega_option101
Awesome work!!
Thanks!
Originally Posted by M0RT3GU1R3
Very cool, I bet it was going to be a pain in the ass to sift through all the Lego pieces to get one color out rite?
That was the biggest drawback lol. But the kinda good news, is these lego were taken from a previous lego PC that I had lying around un-used and still partially assembled. It was somewhat easy grabbing large amounts of the same color.. the hard part was for when it was time to make a retention bracket, or complex workaround and had to find those thinner peices (1/3 height) to secure the item and continue the frame.. what a pita.
Originally Posted by Towik
lol sick
i saw i think like 3 months ago last one of logo cases lol
Yeah, I had done two other ones before this one, and another one which I have no pictures of because it was poorly designed and the atx header came loose and nothing could run. Worst part is I couldnt access it to secure it, so had to start ofer with a more efficient design.
