1 - 20 of 64 Posts
This project is a prelude to the Indigo projects rejuvenation; a hardware and cooling upgrade.
Currently Indigo is armed with an Asus A8N32-SLI Deluxe / x2 3800 + / 7900GT (volt-modded) / 2 x 1GB DDR Kingston RAM.
As much as I love the Manchester, and considering it is my first true love
, it was a difficult decision to replace it.
Anvil will be a test bench for liquid cooling, and the platform that I will use to configure the updated hardware and cooling for Indigo. This 2-tier, multi-stage project will be happening simultaneously with the plastic-surgery that Indigo will require to accomodate liquid cooling.
This project will be started within the fortnight, after I have finished the current Panel Project that I am working on. I already have all of the hardware required, but some of it needs a thorough cleaning and overhaul before it can be put to use.
For starters, here are some images of Anvil in the making.
Gemini was the organ-donor for the liquid cooling components. One loop goes to Anvil, the other will go to Indigo.
Looks nifty, I look forward to seeing this progress.
Originally Posted by edeekeos View Post
looks teh secks.
they always do don't they?
Sweet a new Syrillian project to follow. Man I love your work.
B.O.W
Subscribed
"organ doner"
XD
Subscribed
Again, it's a privilege to witness your craftsmanship.
Discussion Starter · #13 ·
...did a lot planning today [read: staring out into space with a vaccuous look in the eyes]
...how am I going to integrate a dual 120 water loop into Indigo without adding anymore weight.... hahhahaah.... that ain't happenin' in this Universe.
Okay... how about "how am I going to integrate a dual 120 loop into Indigo's current framework...?
...I think I got it.
Ponderous man, really ponderous.
Hmm....that sounds like my Hummer won't fit in my garage so I'll just have to park it on the roof of the garage.....You'll make it fit or you will make the case fit it.
Hahaha, subscribed
Discussion Starter · #17 ·
Ice...
...good analogy.
The estimated placement of the cooling loop components will improve the overall balance of the case (at least that is what I am telling myself
). The case has yet to tip over, it has even weathered 2 small earthquakes; so it really isn't an issue.... I guess....
Oh! and I made a false statement earlier.... bad memory and all.
The rad that will go on indigo is the one from the Prometheus project, not Gemini. Those went on this one (Anvil) and the VF1000.
dam here syrillian goes again! whyd gemini get stripped T_T wahh =P case itself looks nice already.. cant wait to see the progress
1 - 20 of 64 Posts
