After seeing how expensive some laptop coolers can be I did not want to buy two for my laptops. I had some extra wood in the garage so I decided to make my own. Enjoy!
Well since its like 20 degrees in my garage I turned my bar into a work station.
This is my homeade power supply for the fans.
This is the bottom of the whole unit. As you can see I decided not to use the fan contolers because the fans were already very quiet even at top speed.
There is my nice wiring for the switch. It was kind of a hassle becuase the switch runs on 120vac, but its a cool switch.
There is the completed laptop cooler from the front. I think I may put some lights in it later.
Another view from the front, you can kind of see the switch light.
And there is a completed view from the back.
Comments or suggestions are welcome.
Ken Man The Mod Man
Ken Man The Mod Man
