1 - 11 of 11 Posts
Hello guys
This is really annoying, and I don't know how to fix it :|.
What I have here:
1 newish laptop
2 old desktops
2 10m ethernet cables attached to a network switch
Both ethernet cables work just fine when I plug them into my laptop. The laptop notifies me and tells me its connected. However when I plug either ethernet cable in the 2 desktops, they don't work
The link light doesn't come on, both PCs have the network drivers installed, and both of them just say no network cable connected.
One of the 2 PCs has been connected with a shorter cable for weeks, but doesn't want to detect a 10m cable.
I am totally confused. Any help or ideas on why this may be would be appreciated
thanks
Tom
notNOTmbudden
Have you checked to see if it was a hardware problem? Try using the cable you use for the laptop with the desktops and see if they connect. If they do, maybe you need to go get other Ethernet cables.
your ethernet cables might not be wired properly. Newer hardware, especially ASUS boards can figure it out but it will just confuse older computers.
Try setting the speed duplex to 10mbps and not autonegociation.
Discussion Starter #4
Hi
How would I do that?
Does the network card shows up in device manager on the desktop? Do you see any lights on the network card when you plug the cable into the desktop?
Discussion Starter #6
Device properties > Advanced | gives me no option to change the Speed duplex.
It's onboard. And yeah, it shows up in device manager, but no light comes on when cable is plugged in both ends.
Originally Posted by colo View Post
Hi
Its pretty annoying to change ethernet cables, you have to line up all the little wires into the RJ45 connector and then clamp it with a special tool...
I hate it
Try going into your properties for your network card and check out power management tab. Make sure you're not allowing the computer to turn it off.
Expand Always in Always
Is there a X or ? going thru the nic's in device manager?Try uninstalling & rebooting.
are you sure? Have you in the advance tab you should see a big load of selections and one of them is speed and duplex.
Also the latest chipset drivers from amd or nvidia will help.
1 - 11 of 11 Posts
