Originally Posted by ThaWaxShop well basically if you go around 3/8 tube or bigger youll be using barbed |
Originally Posted by pauldovi I think the screw down give you more leak security, but the others look better. Personnel preference, as there are people with great watercooling systems using both. I use the scew for ease of use, reliablility, and cost. |
Originally Posted by DrDeville No compression fittings in that size? I suppose the variation in OD makes it hard too... With clamps or tie-downs, that's a non issue. |
Originally Posted by DrDeville Hey Paul, I'm not sure of the terminology. What do you mean by "screw down"? Thanks! |
