Computer Build
245 Views 8 Replies 6 Participants Last post by  richardshewfelt
ok i was wondering after building you computer putting all the hardware together and everthing when i go to put the OS in and run it will there be anything else i have to do to complete this computer?
1 - 9 of 9 Posts
Download Firefox, Overclock....
But srsly, after that have fun, and do what you want to it.
You will have to install the drivers for you motherboard, and then all your programs, but other then that nope
so i wont have to format my HDDs? how do i instal drivers for motherboard?
the drivers should have been given to you on a disc when you purchased your motherboard, if you lost or didn't get one you go to the manufacturer's site and download them from there. i usually do the 2nd option just to make sure i get the most recent drivers.
From what i can tell its a stock HP/Compaq motherboard??
Originally Posted by richardshewfelt View Post
the drivers should have been given to you on a disc when you purchased your motherboard, if you lost or didn't get one you go to the manufacturer's site and download them from there. I usually do the 2nd option just to make sure i get the most recent drivers.
+1
You will need to format the harddrives when installing your operating system.
This is correct, although as far as i know window instal discs do that for you, and if your using vista, or server 2003 i know for a fact that both of them will create a folder "windows.old" with everything before the reformat in it so you loose nothing.
1 - 9 of 9 Posts
