1 - 2 of 2 Posts
Just about 90% of the time when I plug in a USB device (external HD, ipod, etc) my computer will just lock up...can't move mouse, can't even control alt delete...nothing so of course I'm forced to reboot.
I haven't found many solutions except the one Linked Here. So I make the notepad dialog and add it to the registry, but then the second step is to "Unplug ALL usb devices" and proceed to Device Manager to "Uninstall all devices under USB controllers" well both my mouse and keyboard are USB devices, so obviously if I unplug them nothing works, so I just attempt to uninstall what I can and of course eventually it uninstalls the drivers for my mouse and keyboard therefore rendering them useless... I have no idea what to do but this is extremely annoying and I refuse to accept it. I have the latest BIOS on my motherboard
Mobo: Asus M4A87TD/USB 3
Windows 7 Professional 64bit SP1
12GB Ram
All "important updates" are installed (windows update) but I know this isn't the problem because I had about 25 to install for months now and never had these USB errors.
Obviously I'd like to avoid doing a clean install of my OS but if that's what I have to do Ill do it.
If you have an extra hard drive (or can make a new partition), a way to test if this is a hardware vs software issue is to install a clean copy of Windows and see if you can replicate the problem. If it still exists, then you know it's a problem with the hardware.
How long ago did this issue start happening? Can you think of any new software you may have installed roughly when the symptoms began?
1 - 2 of 2 Posts
