Originally Posted by Frozen-Liquid
its your graphics card too. you will get less high performance running high resolution with HDTV, stress on the gpu.
My card runs at 1600x1200 res without a problem isn't that higher then 720p res?
Im hooking it up to a 42inch plasma samsung 720p HDTV.
The thing is when i look at CCC it says it has HDTV settings then i hooked up my computer my HDTV and those HDTV settings in the CCC were not there... i was thinking maybe i was using a wrong cord.
The cord i used to connect my PC to the HDTV is the cord that came with my 20.1 inch samsung LCD monitor. Im not possitive what the cord is called.
I just unplugged the cord from the back of my monitor and plugged it into the PC port on the back of the samsung HDTV.
