1 - 13 of 13 Posts
Like as if a fan blade hit something. Sometimes it is like a cracking sound. When I look inside the case, I see nothing out of the ordinary.
It has been doing this since I built it in January 2012.
Things I've noticed:
Sound seems to come from the front of the case.
Seems to happen more often when I am playing a game.
Sometimes, after a shutdown, I'll hear a pop or crack after a few minutes. After that, it will be quiet till the next boot.
Sometimes I don't hear a sound for a while, other times it is quite often.
my gtx 570 DC II,,,makes a ticking sound,,,only when the fans are between 50-54%,,so i set the fan curve to jump up right past that point,,,not an issue now
have you ever thought of unplugging each case fan one at a time,and see what happens
Could be a number of things:
1. Coil whinge from the bearings
2. Somethings maybe too close to one of your fans etc
3: Psu plugs not seated properly or in slot.
4. Might not even be that might be interference from an audio lead near power cables? This ;is a rule of car sound as the power wire creates distortion in the audio lead line.
Hope some of my suggestions help, post back more so we know how you went.
Discussion Starter · #6 ·
Well I tried something just now. I played a round of Battlefield 3 (because I noticed it happened more often when playing a demanding game) with the side panel off and my speakers off too. Not a single pop/crack or anything.
Just played a round with the speakers on but the side panel off. No pops/crackles.
Well, keep on keeping on and just keep us informed. Really though, I would make a backup just in case your HDD is about to go tits up.
Discussion Starter · #9 ·
Okay, so I playing some Battlefield 3 single-player with the case closed and speakers on. Popping/cracking sounds returned. Then I paused the game and removed the side panel. Popping/cracking sounds basically gone or very rare.
Is this a heat issue? I have my case fans on the highest speed setting.
gremlins
Discussion Starter · #11 ·
1 - 13 of 13 Posts
