Try setting the video card back to stock. Reinstall the drivers.
Reinstall drivers? What are the GPU temps when this started happening? Do you think you may have overheated the videocard?
What I would suggest is to swap out the video card and see if the problem persists.
Also, please check if the PCIE power is plugged in properly. It could very well be just a loose cable.
Good Luck.
