1 - 8 of 8 Posts
After apply some new thermal paste to my CPU, I put everything back in the computer but when I turned it on, it told me it wasn't able to start and now its "checking" windows to find the problem. Using the setup repair. I don't know what to do!
Originally Posted by superste2201;14228337
Ah sure go for it. Did you shutdown ok? Sometimes a power cut or bad shutdown will cause windows 7 to do this.
No all I did was turn it off and apply--
YAAAYYYY as I wrote this, Windows boot!
Thanks!
Stealin Yer Sammich!
Fastest problem solved ever?
Discussion Starter · #8 ·
Originally Posted by superste2201;14228379
Good! Now you can check your temps with your new TIM
With new Arctic Silver, idle at 27. Run Firefox at 30.
1 - 8 of 8 Posts
