My computer won't boot up after being attacked by spyware/malware. I was using Firefox with Adblock Plus plugin and it did not helped. Now when I reboot, it won't boot up in regular mode. I have ccleaner/spybot/adaware/kaspersky installed and none are working (kaspersky hasn't finished scanning)
I can still boot in safe mode so I know it's not my hardware.
When I start up my computer I get this:
Which reads:
Video @ http://www.zshare.net/video/63523115ea9aafc0/
Any ideas?
Which reads:
A problem has been detected and Windows has been shut down to prevent damage to your ocmputer. If this is the first time you've seen this Stop error screen, restart your computer. If this screen appears again, follow these steps: Check to be sure you have adequate disk space. If a driver is identified in the stop message, disable the driver or check with the manufacturer for driver updates. Try changing video adapters. Check with your hardware vendor for any mscs updates, 0 .......... |
Any ideas?
