Nothing comes up on the screen? Do you get the screen test pattern? Or no input signal message?
If not, it might be a monitor issue, or the monitor cable.
And the system was working fine before you changed the RAM? Or is this a new build that was just waiting on the RAM?
And hey, it's not the socket on the 775 I hate.....it's the ******ed heat sink mount design that I hate. the socket is fine
