1 - 4 of 4 Posts
Does anyone no of a way to make a condensation proof computer with very little money ive made a homemade water cooler and i would like to make it as cold as i can any help would be wikid<br><br>
Thanks<br>
Ryan
ok watercooling will not make condesation unless it has a chiller in it. And yes condensation proofing a comp is pretty cheap. All you need is a little bit of neopreme and some die-electric grease.
<div>Originally Posted by <strong>Leprachuan</strong></div>
<div style="font-style:italic;">ok watercooling will not make condesation unless it has a chiller in it. And yes condensation proofing a comp is pretty cheap. All you need is a little bit of neopreme and some die-electric grease.</div>
</td>
</tr></table></div>
Approved
Use conformal coating around the CPU socket a couple of inches and on the back of the mobo all around where the cpu is...Di-electric in the CPU socket..I dont know if you need neoprene unless you are going sub-ambient...If you are not thinking of a way to go sub-ambient with your WC rig you wont need it at all..LINK...<a href="http://www.dangerdenstore.com/home.php?cat=31" target="_blank">Danger Den :: Peltiers/PSU/Insulation :: Insulation Parts</a>
Reactions: fstfrddy
1 - 4 of 4 Posts
