configure: error: cannot run C compiled programs
6236 Views 0 Replies 1 Participant Last post by  superk
NVM FIGURED IT OUT
This is what I get when trying to compile apache.
root# ./configure
checking for chosen layout... Apache
checking for working mkdir -p... yes
checking build system type... arm-apple-darwin9.4.1
checking host system type... arm-apple-darwin9.4.1
checking target system type... arm-apple-darwin9.4.1
Configuring Apache Portable Runtime library ...
checking for APR... yes
setting CC to "arm-apple-darwin9-gcc"
setting CPP to "arm-apple-darwin9-gcc -E"
setting CFLAGS to " -O2"
setting CPPFLAGS to " -DDARWIN -DSIGPROCMASK_SETS_THREAD_MASK -no-cpp-precomp"
setting LDFLAGS to " "
Configuring Apache Portable Runtime Utility library...
checking for APR-util... yes
adding "-L/apl/sys/ad9/lib" to LDFLAGS
checking for gcc... arm-apple-darwin9-gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... configure: error: in `/var/root/httpd-2.2.11':
configure: error: cannot run C compiled programs.
If you meant to cross compile, use `--host'.
See `config.log' for more details.
Here is my config.log
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.63.  Invocation command line was
  $ ./configure
## Platform. ##
hostname = iTouch
uname -m = iPod2,1
uname -r = 9.4.1
uname -s = Darwin
uname -v = Darwin Kernel Version 9.4.1: Mon Dec  8 21:02:57 PST 2008; root:xnu-1228.7.37~4/RELEASE$
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = unknown
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = Mach kernel version:
         Darwin Kernel Version 9.4.1: Mon Dec  8 21:02:57 PST 2008; root:xnu-1228.7.37~4/RELEASE_A$
Kernel configured for a single processor only.
1 processor is physically available.
1 processor is logically available.
Processor type: armv6 (arm v6)
Processor active: 0
Primary memory available: 116.00 megabytes
Default processor set: 26 tasks, 146 threads, 1 processors
Load average: 0.97, Mach factor: 0.02
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /sbin
PATH: /bin
PATH: /usr/bin/X11
PATH: /usr/games
## Core tests. ##
configure:2500: checking for chosen layout
configure:2502: result: Apache
configure:3307: checking for working mkdir -p
configure:3323: result: yes
configure:3340: checking build system type
configure:3358: result: arm-apple-darwin9.4.1
configure:3380: checking host system type
configure:3395: result: arm-apple-darwin9.4.1
configure:3417: checking target system type
configure:3432: result: arm-apple-darwin9.4.1
configure:3504: checking for APR
configure:3589: result: yes
configure:3864: checking for APR-util
configure:3949: result: yes
configure:4197: checking for gcc
configure:4224: result: arm-apple-darwin9-gcc
configure:4456: checking for C compiler version
configure:4464: arm-apple-darwin9-gcc --version >&5
arm-apple-darwin9-gcc (GCC) 4.2.1 (Based on Apple Inc. build 5555)
Copyright (C) 2007 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:4468: $? = 0
configure:4475: arm-apple-darwin9-gcc -v >&5
Using built-in specs.
Target: arm-apple-darwin9
Configured with: ../llvm-gcc-4.2/configure --build=x86_64-unknown-linux-gnu --host=arm-apple-darwi$
Thread model: posix
gcc version 4.2.1 (Based on Apple Inc. build 5555)
configure:4479: $? = 0
configure:4486: arm-apple-darwin9-gcc -V >&5
arm-apple-darwin9-gcc: '-V' option must have argument
configure:4490: $? = 1
configure:4513: checking for C compiler default output file name
configure:4535: arm-apple-darwin9-gcc  -O2  -DDARWIN -DSIGPROCMASK_SETS_THREAD_MASK -no-cpp-precom$
/usr/bin/ld: warning -L: directory name (/apl/sys/ad9/lib) does not exist
configure:4539: $? = 0
configure:4577: result: a.out
configure:4596: checking whether the C compiler works
configure:4606: ./a.out
./configure: line 4608: 10135 Killed                  ./$ac_file
configure:4610: $? = 137
configure:4617: error: in `/var/root/httpd-2.2.11':
configure:4621: error: cannot run C compiled programs.
## Cache variables. ##
ac_cv_build=arm-apple-darwin9.4.1
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_host=arm-apple-darwin9.4.1
ac_cv_mkdir_p=yes
ac_cv_prog_ac_ct_CC=arm-apple-darwin9-gcc
ac_cv_target=arm-apple-darwin9.4.1
## Output variables. ##
APACHECTL_ULIMIT=''
APR_BINDIR='/usr/bin'
APR_CONFIG='/usr/bin/apr-1-config'
APR_INCLUDEDIR='/usr/include/apr-1'
APR_VERSION='1.2.12'
APU_BINDIR='/usr/bin'
APU_CONFIG='/usr/bin/apu-1-config'
APU_INCLUDEDIR='/usr/include/apr-1'
APU_VERSION='1.2.12'
AP_BUILD_SRCLIB_DIRS=''
AP_CLEAN_SRCLIB_DIRS=''
AP_LIBS=''
AWK=''
BUILTIN_LIBS=''
CC='arm-apple-darwin9-gcc'
CFLAGS=' -O2'
CORE_IMPLIB=''
CORE_IMPLIB_FILE=''
CPP='arm-apple-darwin9-gcc -E'
CPPFLAGS=' -DDARWIN -DSIGPROCMASK_SETS_THREAD_MASK -no-cpp-precomp'
CXX=''
CXXFLAGS=''
DEFS=''
DSO_MODULES=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
EXEEXT=''
EXTRA_CFLAGS=''
EXTRA_CPPFLAGS=''
EXTRA_CXXFLAGS=''
EXTRA_INCLUDES=''
EXTRA_LDFLAGS=''
EXTRA_LIBS=''
GREP=''
HTTPD_LDFLAGS=''
HTTPD_VERSION=''
INCLUDES=''
INSTALL=''
INSTALL_DSO=''
INSTALL_PROG_FLAGS=''
LDFLAGS='  -L/apl/sys/ad9/lib'
LIBOBJS=''
LIBS=''
LIBTOOL=''
LN_S=''
LTCFLAGS=''
LTFLAGS=''
LTLIBOBJS=''
LT_LDFLAGS=''
LYNX_PATH=''
MKDEP=''
MKINSTALLDIRS=''
MK_IMPLIB=''
MODULE_CLEANDIRS=''
MODULE_DIRS=''
MOD_ACTIONS_LDADD=''
MOD_ALIAS_LDADD=''
MOD_ASIS_LDADD=''
MOD_AUTHNZ_LDAP_LDADD=''
MOD_AUTHN_ALIAS_LDADD=''
MOD_AUTHN_ANON_LDADD=''
MOD_AUTHN_DBD_LDADD=''
MOD_AUTHN_DBM_LDADD=''
MOD_AUTHN_DEFAULT_LDADD=''
MOD_AUTHN_FILE_LDADD=''
MOD_AUTHZ_DBM_LDADD=''
MOD_AUTHZ_DEFAULT_LDADD=''
MOD_AUTHZ_GROUPFILE_LDADD=''
MOD_AUTHZ_HOST_LDADD=''
MOD_AUTHZ_OWNER_LDADD=''
MOD_AUTHZ_USER_LDADD=''
MOD_AUTH_BASIC_LDADD=''
MOD_AUTH_DIGEST_LDADD=''
MOD_AUTOINDEX_LDADD=''
MOD_BUCKETEER_LDADD=''
MOD_CACHE_LDADD=''
MOD_CASE_FILTER_IN_LDADD=''
MOD_CASE_FILTER_LDADD=''
MOD_CERN_META_LDADD=''
MOD_CGID_LDADD=''
MOD_CGI_LDADD=''
MOD_CHARSET_LITE_LDADD=''
MOD_DAV_FS_LDADD=''
MOD_DAV_LDADD=''
MOD_DAV_LOCK_LDADD=''
MOD_DBD_LDADD=''
MOD_DEFLATE_LDADD=''
MOD_DIR_LDADD=''
MOD_DISK_CACHE_LDADD=''
MOD_DUMPIO_LDADD=''
MOD_ECHO_LDADD=''
MOD_ENV_LDADD=''
MOD_EXAMPLE_LDADD=''
MOD_EXPIRES_LDADD=''
MOD_EXT_FILTER_LDADD=''
MOD_FILE_CACHE_LDADD=''
MOD_FILTER_LDADD=''
MOD_HEADERS_LDADD=''
MOD_HTTP_LDADD=''
MOD_IDENT_LDADD=''
MOD_IMAGEMAP_LDADD=''
MOD_INCLUDE_LDADD=''
MOD_INFO_LDADD=''
MOD_ISAPI_LDADD=''
MOD_LDAP_LDADD=''
MOD_LOGIO_LDADD=''
MOD_LOG_CONFIG_LDADD=''
MOD_LOG_FORENSIC_LDADD=''
MOD_MEM_CACHE_LDADD=''
MOD_MIME_LDADD=''
MOD_MIME_MAGIC_LDADD=''
MOD_NEGOTIATION_LDADD=''
MOD_OPTIONAL_FN_EXPORT_LDADD=''
MOD_OPTIONAL_FN_IMPORT_LDADD=''
MOD_OPTIONAL_HOOK_EXPORT_LDADD=''
MOD_OPTIONAL_HOOK_IMPORT_LDADD=''
MOD_PROXY_AJP_LDADD=''
MOD_PROXY_BALANCER_LDADD=''
MOD_PROXY_CONNECT_LDADD=''
MOD_PROXY_FTP_LDADD=''
MOD_PROXY_HTTP_LDADD=''
MOD_PROXY_LDADD=''
MOD_REWRITE_LDADD=''
MOD_SETENVIF_LDADD=''
MOD_SO_LDADD=''
MOD_SPELING_LDADD=''
MOD_SSL_LDADD=''
MOD_STATUS_LDADD=''
MOD_SUBSTITUTE_LDADD=''
MOD_SUEXEC_LDADD=''
MOD_UNIQUE_ID_LDADD=''
MOD_USERDIR_LDADD=''
MOD_USERTRACK_LDADD=''
MOD_VERSION_LDADD=''
MOD_VHOST_ALIAS_LDADD=''
MPM_LIB=''
MPM_NAME=''
MPM_SUBDIR_NAME=''
NOTEST_CFLAGS=''
NOTEST_CPPFLAGS=''
NOTEST_CXXFLAGS=''
NOTEST_LDFLAGS=''
NOTEST_LIBS=''
OBJEXT=''
OS=''
OS_DIR=''
OS_SPECIFIC_VARS=''
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PCRE_CONFIG=''
PICFLAGS=''
PILDFLAGS=''
PKGCONFIG=''
PORT=''
POST_SHARED_CMDS=''
PRE_SHARED_CMDS=''
RANLIB=''
RM=''
RSYNC=''
SHELL='/bin/sh'
SHLIBPATH_VAR='DYLD_LIBRARY_PATH'
****CFLAGS=''
SH_LDFLAGS=''
SH_LIBS=''
SH_LIBTOOL=''
SSLPORT=''
SSL_LIBS=''
UTIL_LDFLAGS=''
ab_LTFLAGS=''
abs_srcdir=''
ac_ct_CC='arm-apple-darwin9-gcc'
ap_make_delimiter=''
ap_make_include=''
bindir='${exec_prefix}/bin'
build='arm-apple-darwin9.4.1'
build_alias=''
build_cpu='arm'
build_os='darwin9.4.1'
build_vendor='apple'
cgidir='${datadir}/cgi-bin'
checkgid_LTFLAGS=''
datadir='${prefix}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE}'
dvidir='${docdir}'
errordir='${datadir}/error'
exec_prefix='${prefix}'
exp_bindir='/usr/local/apache2/bin'
exp_cgidir='/usr/local/apache2/cgi-bin'
exp_datadir='/usr/local/apache2'
exp_errordir='/usr/local/apache2/error'
exp_exec_prefix='/usr/local/apache2'
exp_htdocsdir='/usr/local/apache2/htdocs'
exp_iconsdir='/usr/local/apache2/icons'
exp_includedir='/usr/local/apache2/include'
exp_installbuilddir='/usr/local/apache2/build'
exp_libdir='/usr/local/apache2/lib'
exp_libexecdir='/usr/local/apache2/modules'
exp_localstatedir='/usr/local/apache2'
exp_logfiledir='/usr/local/apache2/logs'
exp_mandir='/usr/local/apache2/man'
exp_manualdir='/usr/local/apache2/manual'
exp_proxycachedir='/usr/local/apache2/proxy'
exp_runtimedir='/usr/local/apache2/logs'
exp_sbindir='/usr/local/apache2/bin'
exp_sysconfdir='/usr/local/apache2/conf'
host='arm-apple-darwin9.4.1'
host_alias=''
host_cpu='arm'
host_os='darwin9.4.1'
host_vendor='apple'
htcacheclean_LTFLAGS=''
htdbm_LTFLAGS=''
htdigest_LTFLAGS=''
htdocsdir='${datadir}/htdocs'
htmldir='${docdir}'
htpasswd_LTFLAGS=''
httxt2dbm_LTFLAGS=''
iconsdir='${datadir}/icons'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
installbuilddir='${datadir}/build'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/modules'
localedir='${datarootdir}/locale'
localstatedir='${prefix}'
logfiledir='${localstatedir}/logs'
logresolve_LTFLAGS=''
mandir='${prefix}/man'
manualdir='${datadir}/manual'
nonssl_listen_stmt_1=''
nonssl_listen_stmt_2=''
oldincludedir='/usr/include'
other_targets=''
pdfdir='${docdir}'
perlbin=''
progname=''
program_transform_name='s,x,x,'
proxycachedir='${localstatedir}/proxy'
psdir='${docdir}'
rel_bindir='bin'
rel_cgidir='cgi-bin'
rel_datadir=''
rel_errordir='error'
rel_exec_prefix=''
rel_htdocsdir='htdocs'
rel_iconsdir='icons'
rel_includedir='include'
rel_installbuilddir='build'
rel_libdir='lib'
rel_libexecdir='modules'
rel_localstatedir=''
rel_logfiledir='logs'
rel_mandir='man'
rel_manualdir='manual'
rel_proxycachedir='proxy'
rel_runtimedir='logs'
rel_sbindir='bin'
rel_sysconfdir='conf'
rotatelogs_LTFLAGS=''
runtimedir='${localstatedir}/logs'
sbindir='${exec_prefix}/bin'
shared_build=''
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/conf'
target='arm-apple-darwin9.4.1'
target_alias=''
target_cpu='arm'
target_os='darwin9.4.1'
target_vendor='apple'
## confdefs.h. ##
#define PACKAGE_NAME ""
#define PACKAGE_TARNAME ""
#define PACKAGE_VERSION ""
#define PACKAGE_STRING ""
#define PACKAGE_BUGREPORT ""
configure: exit 1
1 - 1 of 1 Posts
1 - 1 of 1 Posts
