1 - 3 of 3 Posts
Guru Meditation
I'm wondering which power cable to use with a monitor or PSU:
for example my current monitor is plugged with a C13 H05VV-F 3G 0.75 qmm, i'm asking because i think i mismatched PSU power cables with monitor cables. How do i know which is for PSU and which is for monitor ?
Guru Meditation
Originally Posted by TheOwlHootHoot View Post
I don't think it matters unless your PSU is rated for over 1000W. I think the cable should both be 10A. You can always double check and there should be no need to swap.
Thank you, i have 3 monitors and i am a bit worry about using a PSU power cord on my monitors. I emailed to EIZO to ask about this, i hope they will answer.
1 - 3 of 3 Posts
