Originally Posted by
ShoehornHands
Thanks guys, I really appreciate the quick responses. I've now realized that the wording in my original post was ambiguous so let me rephrase my questions.
My idle and load voltages ARE throttling correctly. I'm referring specifically to the voltage fed to the processor at load as you increase the turbo multiplier. Leaving everything else at default settings and just changing the turbo multiplier, my processor is not being fed more voltage. Regardless of what I set the turbo multiplier to, under load it is drawing 1.256 V (at idle it IS correctly throttling down to 0.800ish). I thought that as you increase the multiplier,
the SVID will increase the voltage fed to the CPU. Is this correct? If so, why is my load voltage not changing with increased multiplier? Additionally, I am able to increase the voltage manually by adjusting the offset myself as well as using manual voltage. I'm just trying to understand what exactly is going on. Thanks again for your help.
