1 - 20 of 32 Posts
Hey all - doing a new OC on a new rig with the specs showing below...
First, I slowed the RAM down, decreased my multiplier and increased my FSB till I found my stable max FSB.
I was then going to try to find my RAM's max FSB, but as far as I can tell, there's nowhere in my BIOS to change the CPU/memory ratio, or memory voltage. Because of that I skipped the RAM and left the stock timings the same as well.
So, after that, I planned on going straight for the best FSB/multiplier combo... I lowered the FSB down 40mhz, and started raising the multiplier past the stock 10x... The BIOS flashscreen, nor Windows (XP Pro x64) never registered a raise in mhz.
At this point, the multiplier was at 15x - with no raise in CPU ghz at all, with FSB at 205mhz. Leaving the multiplier at 15x, I then raised the FSB back up to 245mhz (the max I had reached earlier). Rebooted - didn't post. I changed the multiplier to 10x (back to stock multi), left FSB at 245...
Stock CPU ghz was 2ghz, now, with no changes except to FSB, I'm getting 2.45 ghz.. with FSB at 245mhz and multi at stock 10x.
What am I missing here? Why won't the multi affect the processor speed?
Thanks all for any info.
Edit: Typos
Hmm? I am saving and exiting. When I do, it reboots with the changes.
That's not the problem. Like I said, I do see an increase in CPU speed. But, it's only when I increase the FSB. When I raise the multi - nothing increases.
On that cpu the miulti is locked ..Only on the FX serires are the multi,s ulocked it may let you up it in the bios but it will default to standard every time ...Use the fsb to oc the chip
Discussion Starter #5
Was it intended to be like that? What would be the reason for not allowing a multi increase? If I find my stable max FSB, is it the same as finding the stable max multi in my case?
Discussion Starter #6
Can anyone chime in on my last post? Why do I have to use the FSB to increase the speed, rather than just raise the multiplier? And, why can't I raise the multiplier to begin with?
You can't raise the multiplier because it is locked at 10. A 4200+ Manchester is just a 3800+ X2 with a 11x multi instead of a 10. They also unlock the multiplier on the FX chips to make them more "special".
Check the ASRock website for BIO updates.
I do not have any experience with ASRock, but most of the Asus MoBo's that I have used have an updated BIOS that allows the user to change Multi. Perhaps ASRock is similar...
Good luck!
P.S. - Check out V1.2 on the following page:
http://www.asrock.com/support/downlo...Dual-VSTA#bios
hmmm? fx's are the only ones with unlocked multi's? mine isnt locked on my 3500 venice. ive used anywhere from 9 to 11 multi , and no it doesnt default to the standard 11 when i save and exit out. im using 10.5 right now
I can use all multi's upto x12 on my 3800+ venice. This locked multi business confuses me
Bod ***s rock
the multis are downward unlocked meaning you can use a lower multi than stock to increase you system speed for example 220MHzx10 is faster than 200MHzx11 tyhe only chips that are unlocked upwards are the FX series
Really? So how is it when i set my FSB to 250Mhz with a multi of x12 it actually changes the speed to 3Ghz? Ok it doesn't post but it does change it
Aha now it's making sense...
Discussion Starter #18
See - I'm still confused... My 3800+ Manchester is locked at 10.
I can change the multi up or down all day long but neither my BIOS flashscreen nor Win XP Pro x64 registers the change in multi.. It shows I've changed it IN BIOS, but after saving and exiting - no change.
Only when I change the FSB does it affect my speed.
Yes your stock multi is 10....You can lower it but not raise it..Sorry to be so unclear in my first post....By lowering your multi you can then up the fsb higher to increase mem speed and a faster and more effective oc...M
1 - 20 of 32 Posts
