1 - 11 of 11 Posts
So I'm in need of an item that will let me connect to a wireless network to connect to the internet and then share that internet connection across 2-3 ethernet cables.
Any suggestions?
I should mention I do not have access to the modem or router currently in place.
Overclock Failed...
Originally Posted by ObscureScience View Post
... I do not have access to the modem or router currently in place.
Do you mean "physical" access?
Or do you mean you don't have access to the wireless signal (ie the network to which you want to connect to is a secured network)?
Most wireless networks are secured to prevent people from doing exactly what you want to do.
If it's an "open" wireless signal all you need is a wireless card for your computer. Then, when you have access to the internet, you can create a network using Windows Home Networking to connect any wired or wireless devices to your computer (and the internet). The legality and morality of doing that, without the owner of the wireless signal's permission, is, well, dubious, at best.
No I mean no physical access. I get my internet from my landlords router, wirelessly.
You could get a "Media Bridge" such as the Linksys WES610N-NP. You can also get an ordinary, DD-WRT-capable router and set it up with DD-WRT in Bridge mode. I use a Dlink DAP-1650 for exactly what you want (my router is in a place I can't run a cable to), but I'm hesitant to recommend it because I have to restart it about once a week. but I'm pretty sure any "Wireless Extender" that has ethernet ports will do what you want.
Anything that you plug into any of the above will act just like its been plugged straight into the back of the wireless router.
Someone on a different forum suggested getting a wireless access point box. Now these usually come with only 1 ethernet port so he suggested using a switch in this port to hook up my 2 computers.
This sound like a good idea?
I have looked into these "wireless extenders" but I see a lot of bad customer reviews for them.
Overclock Failed...
You can get a wireless access point with 4 wired connections.
And, no, an extender won't do what you want to do. It just "rebroadcasts" the a wireless signal. They have no external networking connections.
Overclock Failed...
You'll need to access the landlords router's software. You'll need the password. Then it's just a wireless access point and creating a little personal network.
Discussion Starter · #8 ·
I couldn't find any with more than 1 port at my local webstores. Though it's a bit hard to search for them as they all seem to go by different functionality labels.
Discussion Starter · #9 ·
Oh I wish. Imagine, I could have open ports as well. A boy can dream
I was also going to suggest using a router capable of DD-WRT for doing this.
You can do this with an apple airport extreme. Just set it in extend mode and plug in to the three gigE ports on the back.
1 - 11 of 11 Posts
