I have a HDMI to Mini HDMI cable. I plugged the HDMI into my A/V Receiver and the mini HDMI into my card, since that is what it has. I booted up the receiver, but I'm not seeing any option here...I went to the NVIDIA control panel and I see Digital Audio, but no options, all greyed out.
Is there a guide to hooking up a A/V Receiver via to a NVIDIA graphics card?
Or should I go TOSLINK to my Sound card?
Ah, got it be putting it on a "Game port" instead.
However, I can't see the Receivers Menu's...which are required to tweak settings...frustrating right now.
I also read this means it's basically not using my sound card...should I go optical to that instead, would that be better?
It also seems to be extending the screen, i.e, my mouse can go all the way over into nothingness, like I have a secondary monitor...which it detects the Denon AVR as. If I disable this, I lose audio as well.
Sigh.
Sigh.
