Connecting the PC to the TV via 4870
522 Views 3 Replies 4 Participants Last post by  walno2
Just wondering what the quality would be like if I used a HDMI cable to connect the TV to the PC via a DVI convertor that came with the Graphics card?
What level of quality res would I get?
TV is a 37" LCD HD res
Specs of the PC on Sig!
Looking at options like using windows to actually playing games! When I get some Blu Ray vids I will want to play those as well
Thanks
1 - 4 of 4 Posts
you will be able to run at the tv's resolution, whether it be 720p or 1080p with no problems. Make sure you install the HDMI audio driver for ATI cards and Realtek (if that's what you are using).
and you can also use the svideo or component cable. but hdmi is still better.
Yeah you should be fine. I have mine hooked up to a 26in HDTV (1360x768) native resolution. And it looks great.
1 - 4 of 4 Posts
