1 - 20 of 24 Posts
For the last 24 hours my connection has been going out every few minutes for 5-20 seconds at a time, and then coming back. I called my ISP and they say its nothing on their end. I've directly connected to my moden, restarted my modem and router, disabled and reenabled my network device, just about everything and this is still happening. My speeds are the same though. I get the same speedtest.net results as always and have even downloaded a few files at normal speeds. I've tried closing out bit torrent, steam, and any other app that would use bandwidth and the problem persists. Any help would be appreciated.
What type of connection do you have (DSL, Cable, etc)?
When it drops, do a trace route to determine where the problem is:
Open a command prompt (Start | Run | cmd)
type in: tracert 208.67.222.222
Get a screenshot of the result...
That is basically a simple trace route to an OpenDNS server...
Then it's an issue with the modem, or the cables going from the modem to the wall socket.
Loosing Vision
Most likely the modem. They can be brand new and crap from the Gito!
You can pull the plug on the modem and do a hard reset on it for at least 30 sec's I prefere 60 sec's then isolate it by using one pc only. if it help then continue to hook to addtional routers etc.
I replaced the ethernet cable from my PC to the router and when i had it directly connected to the modem. Ive restarted my modem several times; leaving it unplugged for 30 seconds and pushing the reset button with a pen.
Uhh.... you didn't do that tracert when the connection was down, did you?
At this point, I'd probably b!tch to your ISP and have them send you another modem...
Discussion Starter · #9 ·
I did. Even tried browsing the internet while it was doing so. Got "Connecting to..." in Firefox.
Originally Posted by gonX View Post
DNS problems then. Try navigating to http://67.220.212.115 when it happens again. If it works and http://overclock.net doesn't, then you've found your issue - it's the DNS servers.
Yeah, I agree. Damn I need some sleep....
Zzzzz
Originally Posted by Cretz View Post
Not a DNS issue. Both timed out.
Do you have another computer on the network you can test with? Just to eliminate the possibility that it's your computer....?
Well I get to go the entire weekend until someone comes out on monday with constantly disconnecting internet.
Well, sounds like you've done everything you can on your end. At this point, I would really start to suspect the modem itself.... bummer...
Having the same problem, except with DSL. I have determined it to be my router, because I don't have a modem :|
Now how to explain it to my dad...
"Hey, dad, I think we need a new router."
"WHAT?! WE'VE OWNED THIS FOR 6 YEARS AND HAVE NEVER HAD ANY PROBLEMS WITH IT!"
"It's 6 years old. I think the old tech needs replacement regardless. It's messed up, besides."
Discussion Starter · #20 ·
Ive owned my current router for a bit longer than 6 years and each time I think its my routers fault it turns out its either my ISP or modem.
1 - 20 of 24 Posts
